87 messages.      3 4 5 6 7 8 9   - Logiciel de diagnostic Bosch IBD sans dongle [28510]
Wimhgh
25-11-2021 à 01h54
Tried to send Bitslover101 a private message but seems not to work. Is there some way to get this diagnose software, any working link or other way? Would be very happy if I could find this somewhere or if someone could help me to get it.
Anonyme, 1 msg, (BE-36).
 Citer Alerter [720847]
Pathol
25-11-2021 à 18h28
Merci Bitslover101.
Patrick, 24 msg, 63 ans. Bordeaux (FR-33).
 Citer Alerter [720912]
25-11-2021 à 18h28
Pathol
25-11-2021 à 18h39
@ Bitslover101,
I need the patch for Nyon2, can you put it back?
Thanks.
 Citer Alerter [720913]
Bitslover101
25-11-2021 à 22h21
@Wimhgh: the IBD app link is in this discussion, Bosch official download link.
@Pathol: the patches uploaded are the latest one with nyon2 support.
Anonyme, 10 msg, (FR-75).
 Citer Alerter [720950]
Xabi
26-11-2021 à 08h19
Merci beaucoup Bitslover101
8 msg, 57 ans. (-64).
 Citer Alerter [720969]
Link
26-11-2021 à 10h12
Bitslover101 a écrit :
@ Link: I don't see any messages from you.
PMs seem to be broken (
@ Bitslover101
Could you PLEASE share a keys for lvl 2.
I desperately need to change gear ratio and if I use case 1 key DU does not authenticate (.
Details:
Tried using lvl 1 36DE........ and others. As far as I understand, level 2 keys are needed. Namely cases (slots) 26, 27, 19, 20 and maybe 14 and 15 (ABS) for the write process to work correctly. The 128 bit entropy is too high for brute and perhaps there is another extraction method I'm yet to find. Maybe you could at least point to the right direction?
Please help.
We can talk via linkfor@protonmail.com
Anonyme, 4 msg, (RU-12).
 Citer Alerter [720979]
Pathol
26-11-2021 à 18h22
Je ne savais pas que c'était le même fichier.
Merci.
 Citer Alerter [721023]
Jbl-18
27-11-2021 à 20h39
Le lien du message 717649 ne fonctionne plus.
Quelqu'un aurait-il le fichier qui permettrait d'enlever le message comme quoi le dongle bosch est absent.
D'avance, merci.
Amicalement
3 msg, 63 ans. (-18).
 Citer Alerter [721086]
Xabi
27-11-2021 à 21h13
Bonsoir Jbi-18,
Tu trouveras le lien au message N°720818
Bonne soirée
 Citer Alerter [721095]
27-11-2021 à 21h13
Jbl-18
28-11-2021 à 00h03
Bonsoir,
le lien n'est plus fonctionnel. Ci-dessous le message lorsque l'on clique sur le lien
"Le transfert recherché n'existe pas ou a expiré.
Merci de bien vouloir vous assurer que le lien de téléchargement est correct.
Vous pouvez également contacter l'utilisateur a l'origine de la création de ce transfert pour solutionner le problème rencontré."
 Citer Alerter [721098]
87 messages.      3 4 5 6 7 8 9   - Logiciel de diagnostic Bosch IBD sans dongle. [28510]
